LabWindows/CVI
visa linker error
I'm having some difficulty making use of the NI Visa functions in CVI 9.  If I open up one of the VISA examples in the VXIPNP\WinNT\NIvisa\Examples folder I have no problem.  However, if I create a new UI project such as the below I get the following linker error: "Undefined symbol '_ViOpenDefaultRM'.
#include <utility.h>
#include <visa.h>
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "User Interface Application.h"
#include "toolbox.h"
static int panelHandle;
int main (int argc, char *argv[])
    int error = 0;
 ViStatus status;
 ViSession defaultRM;
    /* initialize and load resources */
    nullChk (InitCVIRTE (0, argv, 0));
    errChk (panelHandle = LoadPanel (0, "User Interface Application.uir", PANEL));
    /* display the panel and run the user interface */
    errChk (DisplayPanel (panelHandle));
    errChk (RunUserInterface ());
 status = ViOpenDefaultRM(&defaultRM);
Error:
    /* clean up */
    DiscardPanel (panelHandle);
    return 0;
Sean
(3,226 Views)
HI Seanovsky,
I think the issue is with your ViOpenDefaultRM.  I believe this should be viOpenDefaultRM, with a lower case v
Hassan Atassi
Director, ni.com
(3,183 Views)
