LabWindows/CVI
visio 2007 ActiveX Controller
             I found that somebody  named DaveC had asked the same question with me. http://forums.ni.com/t5/forums/postpage/board-id/180?message.subject=visio
            It' s about  the  developmment with visio 2007 ActiveX  Controller  in CVI ,but  Nobody has given the solution about this problem.I wonder that Is this question a bug of Labwindows.Could somebody help me!?Thank you very much!
           I say the question again: when I tried using the Visio 2007 Drawing 12.0 ActiveX controller with Labwindows/CVI 8.0? The .API that LabWindows generates works fine when using automation, however the drawing sheet(.vsd file) on the control does not seem to respond to mouse clicks. Oddly enough, the stencil sheet (.vss file) works fine on the control. I can click and drag a stencil onto the drawing sheet and then control it using the keyboard, but the mouse seems non-responsive once the drawing sheet becomes involved.
          Has anyone else used the control and seen this problem, or used the control and not seen the problem? If you have seen the problem, and were able to fix it, how did you do it?
        By the way , I want to get contact with the author  DaveC to ask if he has got the solution of this question ,but i haven' t found his E -mail .I am here the first time .Has somebody tell me how to get the contact with him ,for example by his email!
     Thank you very much !
(3,407 Views)
I have not used the control, but you can try CVI9 for this. furthermore, it may be the control's bug.
(3,365 Views)
