LabWindows/CVI
want to use c++ code inside cvi
have a C++ code that I would like to use inside my cvi project (which is in C) not sure how to integrate the C++ code from visual C++ into my cvi project.
(2,881 Views)
You can do this by creating a dll in VC++ that contains your C++ code. You will need to wrap the C++ code in C function calls so that it can be accessed from CVI.
Alternatively, you could move your CVI project to VC++ entirely, so you end up with a mixed C/C++ application.
Martin
Martin
Certified CVI Developer
(2,881 Views)
