LabWindows/CVI
warning: variable 'av' is uninitialized when used here
This warning seems incorrect in this case:
#include "stdio.h"
union act_val{
    double a;
    int b;
void thing2(union act_val av)
    printf("%d\n", av.b);
int main(int argc, char const *argv[])
    union act_val av;
    av.b = 1;
    thing2(av);
    return 0;
Variable av is uninitialized when used here, at the thing2 call. The warning goes away if the 'a' field is an 'int'. I suppose it is warning me that not all the bytes of the union are being initialised, as double is larger than int here. It seems like half the reason for a union is to be able to deal with a specific field at a time.
Of course I can work around the warning by initialising the 'a' field, I do not like the initialise variables with false values however as it stops genuine warnings and valgrind errors.
(8,488 Views)
Hi evanb,
It seems that LabWindows/CVI performs only minimal checks for union type variables. If a union contains pointers, arrays, or structs, LabWindows/CVI does not maintain user protection information for those objects.
I found that in this link  http://zone.ni.com/reference/en-XX/help/370051M-01/cvi/programmerref/unions/
Have a great day.
(8,453 Views)
Thanks for the reference, but it does not seem relevant here. My union does not contain a pointer, array, or struct. It is not obvious, but that doc might be referencing run time, while I am talking about compile time. I was also under the impression that cvi used clang to compile, clang does not give the same warning, even with -Weverything. The doc is dated 2008, I am using CVI 2017.
(8,446 Views)
Also, this is the documentation that you can find on CVI Help.
 I want to mention this forum, https://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/idb-p/cviideas normally R&D check out this if you have great ideas or thing that you may want to change on CVI.
I found this about clang, https://forums.ni.com/t5/Community-Documents/How-to-build-and-integrate-lastest-clang-compiler-to-CV...
On the readme file of CVI 2017,
The following components and features were deprecated in LabWindows/CVI 2017:
  • NIReports
  • MStudioCW3DGraph
  • Merge Modules installed by LabWindows/CVI in system's merge module directory (C:\Program Files\Common Files\Merge Modules).
  • Support for LabWindows/CVI Library with .NET 1.1 and 2.0
  • LabWindows/CVI versions of the Clang 2.6 and 2.9 compilers shipped with LabWindows/CVI
(8,429 Views)
