LabWindows/CVI
what is tTestData
Hi all
I am very new to LabWindows.
I need to know the structure elements in tTestData
Kindly any one help me in explaining the tTestData structure.
is the following structure correct for tTestData?
typedef struct ClassData_Rec
int result;
double measurement;
char * inBuffer;
char * outBuffer;
char * const modPath;
char * const modFile;
void * hook;
int hookSize;
tMallocPtr const mallocFuncPtr;
tFreePtr const freeFuncPtr;
struct IDispatch * seqContextDisp;
CAObjHandle seqContextCVI;
char * stringMeasurement;
int tReplaceStringPtr const replaceStringFuncPtr;
tTestData;
Kindly clarify me.
Thanks and regards
Bala
(3,468 Views)
It looks like the Test Result data structure used in Test executive program that was available prior to the release of Test stand.
I think that test Stand can call functions that use this structure to pass the test results.
Colin
(3,449 Views)
hi
thanks for the reply
kindy can you say me the variables in the structure tTestData
with regards
Bala
(3,446 Views)
