LabWindows/CVI
what is the definition of if else
standard C allows an "if" statement to be true if the value in the "if" is a non-zero number.  Is this also true of the CVI compliler? If the statement returns a -1, is the "if" true or false?
(2,999 Views)
Yes, the CVI compiler is ANSI compliant, which means that the body of an "if" statement will be executed if the condition evaluates to a non-zero value.
(2,985 Views)
