LabWindows/CVI
when i am making exe from distribution kit in labwindow ver 6.0,i am not able to see toolbar icons,whereas when i run normal source code it runs, what can be troubleshoot,any setting in distribution kit
when i am making an exe from distrubution kit in labwindow ver 6.0 and installing it, it does show toolbar icons,whereas when i run from workspace icons are visible,any settings to be done in distribution kit,u can check in example programs of cvi tooldemo example.
(2,842 Views)
create a directory in your working directory,and transfer all the icon file into it.In distribution kit add new group name as directory name which is having icon files and add all the icon files into it. check the relative path and write the name of group u created, this will solve ur problem
(2,842 Views)
