LabWindows/CVI
where is the "moving average" function in cvi 7.0 ?
Where can find the "Moving Average" function in CVI 7 ?
David
(3,491 Views)
Hello David,
Specifically, which function are you looking for? If you are a refering to a function you used in previous versions of CVI, could you include the name of the function.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,475 Views)
Hi Wendy,
In LabVIEW , there is a vi , "Smoothing Filter Coefficients " , by specify the input type , I can set the filter type as the moving average model , but I can not find such a function in LabWindows/cvi , could you give a specification ?
David
(3,465 Views)
Hello David,
Currently, there is no moving average function in CVI 7.0 comparable to the VI in LabVIEW. If you would like our developers to consider this addition for future releases of CVI, I would suggest posting a product suggestion.
Thanks.
Wendy L
(3,438 Views)
