LabWindows/CVI
which function can i use to programtically change Axis name of graph and strip chart
Hi everyone:
which function can i use to programtically change Axis name of graph and strip chart? Thank you very much!
(3,065 Views)
Hi schoolworkwork,
To change an Axis name programmatically, you need to call the
SetCtrlAttribute function and set the ATTR_XNAME or ATTR_YNAME attribute to whatever you like.  For example, suppose I wanted to change the top X-Axis name of a graph. I would say
SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_ACTIVE_XAXIS, VAL_TOP_XAXIS);    // Make the top or bottom x-axis the active one
SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_XNAME, "Hello there");           // Set the name
Hope this helps!
Best Regards,
Jonathan N.
(3,057 Views)
