I'm sorry but I have not been able to reproduce this. I have opened at least 5 projects in my workspace, opened several source files from different projects, closed them all using Window >> Close All, and then tried to reopen one of the files. Only the one file opens up. I'm wondering if something odd is going on with your workspace. If possible, can you create a new workspace and then add your projects to it and see if it still happens? Otherwise, can you provide a workspace and set of projects that can reproduce this behavior? Thanks!
Jeremy L.
Jeremy L.
