LabWindows/CVI
windows exit button doesn't work
Does anybody know why the windows' red exit button doesn't work for my program?
(4,254 Views)
Did you assign it a close control? In the UI editor, Edit Panel, there is a ring control labelled 'Close control'. Have a closer look there...
(4,253 Views)
The close button is set to be in the menu, so I it's not in tle list of this close control.
What should I do?
(4,247 Views)
Sorry, I did not understand what you mean.
The ring control lists all the controls you have on the panel, and usually there is a QUIT ot EXIT button. You may want to select this one.
What this ring control does is equivalent to setting the ATTR_CLOSE_CTRL programmatically, i.e. you define the ID of the control for which a commit event is generated when you select the Close item in the Windows system menu.
(4,242 Views)
