LabWindows/CVI
windows on-screen keyboard
Hye,
I'm trying to make Windows on-screen keyboard open right after any text box is getting focus,
right now, as default, the user must click the text box twice to activate the keyboard which is a problem, becasue it's on a tablet and not always the 2nd time is in the box and tablet is not real accurate and so on..
so, I want the virtual keyboard to be visable right after the first click,
is there another way or calling OSK.EXE everytime the user click on text-box is the only way?
thanks is advance,
Aj
Amit Joseph,
Software Engineer
(4,498 Views)
In the control callback you could use the event EVENT_GOT_FOCUS to call LaunchExecutable ();
(4,494 Views)
thanks,
but that was my question, if that the only solotion or is there another way to do so?
appreciate the quick response
Aj
Amit Joseph,
Software Engineer
(4,487 Views)
Well, you wrote that "right now, as default, the user must click the text box twice to activate the keyboard which is a problem"...
So I suggested to use EVENT_GOT_FOCUS instead because this event can be triggered without clicking by using the TAB key or Shift-TAB.
(4,483 Views)
you defently right, that soilve my problem 😄 no question about it,
i just thought there is a way (not necessarily as code, but perhaps a setting in windows or somthing like that :D)
thatnks again 🙂
Amit Joseph,
Software Engineer
(4,479 Views)
 after using  LaunchExecutable ("c:\\Windows\\SysWOW64\\osk.exe");
I am getting error like "Could not start On-Screen keyboard"
Thanks.
(4,113 Views)
