LabWindows/CVI
windows2000 problem
hi
it is not a problem from cvi but a problem from win2000!
if someone can help me or give me some hints i would be very happy!!!
We use a device with MS-DOS +ADDON to run a fileserver on this device!
Now i want to open a file on this device with
fopen(\\server\c\str.txt,"w");
but on the win 2000 system the fopen function returns a Null-Pointer
with the errorno EIO (Generall I/O Error)!
fopen(\\server\c\str.txt,"r"); works fine!!!!!
if i will make a Directorymapping to this device (f:\==>\\server\c)
then also the fopen(f:\str.txt,"w"); works fine!!!
Can anyone give me some hints!!
thanks a lot
chris
(3,421 Views)
Have you tried "w+"
Kevin Snelling (Consultant)
Product Technology Partners
"chris" wrote in message
news:39bf8e08@newsgroups.ni.com...
> hi
> thanks a lot
> chris
(3,421 Views)
