05-05-2015 08:24 AM
I have a question about the Word report generation with LabWindows CVI.
I want to check or uncheck some checkboxes with CVI.
I did not find a function in CVI library (Word Report) that changes checkboxes value.
Is it possible to do it (in a simple way)? If this is not the case I will arrange to remove the check boxes.
Danaé P.
05-26-2015 10:08 AM
Hi D1431,
Sorry for the late reply,
There is no functions in CVI word report library that allows to check or uncheck a checkbox in a word report.
However you can use an Active X server in CVI: http://www.ni.com/white-paper/2714/en/ to get access to all the functionalities and functions available for Word (http://www.extendoffice.com/documents/word/993-word-insert-check-box.html for instance).
Hoping it'll help you.
Best Regards
Louis
National Instruments France
