Are you running this exe in debug or release mode? the first thing to do here is to do some run-time error checking to locate the function that is failing. From there we can start doing some more specific debugging.
Also make sure that there are no other applications using word while you are generating the report.
Please give this a try and let me know your findings.
Juan Carlos
N.I.
