LabWindows/CVI
wraping code to an existing fp driver to create a new fp driver
How can I create my own fp driver using an existing NIDAq fp driver. (or any other fp driver) I need to wrap my code around the existing SCXI fp for which the code is restricted. My fp driver will call the SCXI fp driver. The development manual is real vague about this.
(2,945 Views)
I'm not quite sure what you are trying to do here. You have code that you have written. Are you wanting to create an instrument driver with it which calls another instrument driver? Or, are you just building the .fp file and you want that .fp file to call the code for the SCXI instrument driver? Or, do you want the SCXI .fp file to call your code? If it's one of the last two cases, then open Instrument>>Edit. Here, you can attach your code to a particular .fp file. You could use either your code or your .fp file to associate it with other code or another .fp file. Let me know if you are trying to do something else.
J.R. Allen
(2,945 Views)
