LabWindows/CVI
write data to cell in excel
I am trying to write data into a particular cell in an excel. when i am looking into example program i felt bit difficult to understand.
i have wriiten code to read data from particular cell which works well. I am facing difficulties in writing data to cell. pls someone help.
// to read a data from cell which works
           status = Excel_RangeGetItem (rangeHandle, NULL, CA_VariantInt (i+1), CA_VariantInt (j+1), &MyVariant);
            // Get the DISPATCH pointer
            status = CA_VariantGetDispatch (&MyVariant, &MyDispatch);
            // Create a new Range Object from DISPATCH pointer
            status = CA_CreateObjHandleFromIDispatch (MyDispatch, 0, &ExcelSingleCellRangeHandle);
            // Get the value of the Single Cell Range
            status = Excel_GetProperty (ExcelSingleCellRangeHandle, NULL, Excel_RangeValue2, CAVT_VARIANT, &MyVariant);
           status= CA_VariantGetCString(&MyVariant,&val);
 strcpy(cellvalue,val);
// to write data into a cell
 status = Excel_RangeSetItem (rangeHandle, NULL, CA_VariantInt (i+1), CA_VariantInt (j+1), MyVariant);
            status = CA_VariantSetDispatch (&MyVariant, &MyDispatch);
            status = Excel_SetProperty (ExcelSingleCellRangeHandle, NULL, Excel_RangeValue2, CAVT_VARIANT, &MyVariant);
   status= CA_VariantSetCString(&MyVariant,writedata);
i know i am doing some mistake in the above code.
(5,656 Views)
Can someone help. i need to set a value in the ith row and jth column in an excel as i did for reading cell value.
void write_cell_value(int i, int j, char *cellvalue)
 static VARIANT MyVariant;
 status= CA_VariantSetCString(&MyVariant,cellvalue);
  status = Excel_RangeSetItem (rangeHandle, NULL, CA_VariantInt (i), CA_VariantInt (j), MyVariant);
(5,631 Views)
As far as I can see your write_cell_Value function only needs to receive 'rangeHandle' parameter, then it should work correctly. Also cut the static keyword from the definition of MyVariant and free it at the end with CA_VariantClear.
Do you receive any error when running the program?
(5,628 Views)
I removed static keyword and it works. thank  you very much  Roberto.
(5,621 Views)
CA_VariantIsEmpty function can be of help in this respect: if not empty then read the value.
(5,616 Views)
Accepted by topic author ammukrish
Thank you very much Roberto. You have solved my issue.
(5,603 Views)
