LabWindows/CVI
wrong font display in cvi
Anybody,
I'am using Labwindows CVI 8.0 on a Windows XP machine. From the UIR editor it is possible to select a none unicode font (e.g. Arial CYR) and display text correctly. However when I run the program the text is displayed wrongly (see bitmap). On windows 2000 there is no problem. I know that if I setup the regional options in the control panel to the desired language I can use the unicode family name of a font (eg Arial) to display the text correctly. But the problem is that I need to display 2 none unicode fonts (e.g. Arial CYR and Arial TUR) at the same time in two different text controls.
As the UIR editor can do it right why cannot this be at runtime?
(3,133 Views)
Hi fvdl,
The bitmap was missing. Could you please post one? Because I cannot reproduce this. But I have version 8.5.
Bas van Dijke
AE, Netherlands
(3,060 Views)
