LabWindows/CVI
www server: query string possible?
I must write a cvi application to communicate with an iphone and android app. My idea is to use the (simple) web server in cvi. After two hours, the server runs perfect and I can fetch documents from the server.
My question is now: is there any possibility to write data (only a few queries) from the client to the web server, so that the web server is able to detect/utilize the data (client push technology)? All attempts were in vain.
Many thanks in advance
Jürgen
(3,102 Views)
Hi Jürgen,
I'm not 100% sure if I understand you correctly but concerning your topic I found two Links:
Understanding Client-Server Applications -- Part I
http://zone.ni.com/devzone/cda/tut/p/id/4431
Understanding Client-Server Applications -- Part II
http://zone.ni.com/devzone/cda/tut/p/id/4433
Even the code examples are written in Labview you can have the same commands in CVI.
Best Regards
Jan
(3,084 Views)
