LabWindows/CVI
y-axis limit control
I would like to set the maximum and the minimum of the y-axis of a graph programatically.  I tried SetCtrlAttribute or considered SetPlotAttribute, but didn't work.  Of course, I can set it in the property window of the graph, but want to change the max and min in the program.  Can anyone shed light on this?  Thanks in advance.
(3,275 Views)
Hi scatjay,
You need to say something like:
// myMin and myMax are variables of type double that I have already declared which represent my minimum and maximum y-axis range values
SetAxisScalingMode (panelHandle, PANEL_GRAPH, VAL_LEFT_YAXIS, VAL_MANUAL, myMin, myMax);
Best Regards,
Jonathan N.
(3,270 Views)
