LabWindows/CVI
ymodem
Hello
Is there a way to transfer files using the ymodem protocol in Labwindows?
(4,661 Views)
At present, the RS232 library supports XMODEM but neither YMODEM nor ZMODEM
(4,647 Views)
It is unfortunate that Labwindows does not have a library that supports ymodem transfers.
I have a requirement for uploading files from a remote instrument that only supports standard ymodem protocol for binary file transfer.
Can anyone recommend a library or code available for ymodem communication over RS232?
(4,628 Views)
Unfortunatly we only have xmodem so far. So you can get an idea from that, and implement it.
(4,600 Views)
