Life Science
EEG Data
The EEG signal that are received from hospital are in different format. I need EEG data compatible to LabVIEW...
Plz helpme with the EEG signal. I am defining algorithm to detect Neurological disorder from EEG signals.
Thank You all in advance.
(12,710 Views)
You mention the signal format is different...wich format is that ? Are you reading this signal from an equipment ? throught an analog input ? Digital (serial, or different) ?
RKO
(12,689 Views)
  The signal format is ".e" . The signals were got from hospital.
(12,681 Views)
Continued here
Please keep all discussions to a single thread...
(12,644 Views)
