Life Science
I need to measure displacement (angular or liniar) of a mouse wrist joint when applying extenal pulling force (also to measure), in order to build force- displacement curve. Any ideas on sensors I can use?
This is to measure muscle tone in spastic experimental animals.
Amount of force is several gramms, displacement - 15-50 degrees, or can be converted to liniar
(7,426 Views)
Check out the FT03 (Force Displacement Transducer) from Grass. It requires a DC amplifier however I believe it should work for your application.
link to specs...
http://www.grass-telefactor.com/products/transducers/ft03.html
If you do decide to go with this I would suggest the CP122 DC amplifier and don't forget to get a powersupply for it as Grass complicates things by selling them separately.
(7,426 Views)
Alexd,
The Sensors section of the NI Developer Zone has a great deal of useful information regarding sensors. I have included a link to this location below:
NI Developer Zone - Sensors
Specifically, the following Application Note discusses the selection of displacement sensors:
How to Choose Among LVDT, RVDT, Potentiometer, Optical Encoder, Ultrasonic, Magnetostrictive, and Ot...
Good luck with your application.
Spencer S.
(7,426 Views)
