Life Science
créer un VCO par labView6
Bonjour
Je veux créer un VCO par labView6 je sais pas comment faire.
merçi.
(9,066 Views)
I may be able to help. Can you give me more details about the VCO you want to create?
(9,052 Views)
Bonjour
Je veux controller un géneréteur de signaux (sinus, carré...) par une tension lu par une entrer analogique. en fait, je veux que la fréquence des signaux de générateur soit proportionnel à la tension lu.
merçi
En anglais
Hello
I want controller a generetor of signals (sine, square...) by a tension read by one to enter analogical. in fact, I want that the frequency of the signals of generator proportional to the tension is read
merçi
(9,048 Views)
Can you define "VCO" for me?
(9,046 Views)
VCO = voltage controlled oscillators
(9,041 Views)
I found a LabVIEW example program that synchronizes Analog Input with Analog Output. This could be modified to increase the frequency on the output based on the changing input voltages. Here's the link:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=D488F3AF68F150CBE034080020E74861&p_node=200509&p_submitted=N&p_rank=&p_answer=&p_source=External
Does this help?
(9,030 Views)
In regards to your question I found another resource. Take a look at PWM-Analog Output.vi in the daqmx Control/Control.llb example set.
(9,027 Views)
