Linux Users
2019 NI Drivers on ubuntu.
Trying again to get NI drivers working on my mint 19 installation.  I did a rpm download from fedora to get all of the rpm packages, then converted to debs.  Installed everything and when running visaconf i first get an error -1073807360. Reason listed is VISA: Unknown system error.
If i hit continue any changes i try and make give me an error of -5007.  Unexpected error occurred when calling the configuration file library.
Any ideas?
Message 1 of 29
(8,994 Views)
Hi guy,
I am also try to install the NI driver on ubuntu18.04.
But I didn't fix it until now.
Have you got any solution?
Message 2 of 29
(8,922 Views)
I gave up om Linux LabVIEW on Ubuntu and instead installed Centos 7 .x on a separate hard drive. The drivers get installed with LabVIEW during a standard install.
Message 3 of 29
(8,907 Views)
I just switched to Fedora 30, so far so good.
Message 4 of 29
(8,897 Views)
Any issues with Serial ports on CentOS?
I can't the PXI-8433/4 to work.  They are stuck in 2-wire mode.  Property node for Wire Mode is not supported in Linux
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 5 of 29
(8,887 Views)
Okay, got some time to play around some more with this and finally have it working....
I am running linux mint 19.2 with kernel 5.0.0-23.  (should work with ubuntu as long as kernel is not newer.)
This is what i did (Assuming you already have labview for linux 2019 already installed)
Open your terminal and create a tmp folder, cd into it.
then do  "wget -i http://download.ni.com/ni-linux-desktop/2019.07/rpm/ni/el8/"
That should download all the rpms.
Delete any of the i386 rpms ( I think there were 3). Or move them wherever you want.
now run "sudo alien --scripts *.rpm" This will take awhile.
When finished run "dpkg -i *.deb"   (Again, will take a while, i just installed everything, but obviously you don't have to.)
When finished run "sudo dkms autoinstall"
When finished run "visaconf"
That should be it. Good luck!
Message 6 of 29
(8,873 Views)
Will this work for LabVIEW 2018 RTE? I just want to be able to run a LabVIEW.exe I created in LabVIEW for Linux on another Linux OpenSuse machine.
Message 7 of 29
(8,834 Views)
I need to be able to run a LabVIEW.exe on Ubuntu only using LabVIEW RTE. I tried using the Alien function to unpackage and install all the rpm files but now I'm having a bunch of missing library errors when trying to run my LabVIEW application.
Message 8 of 29
(8,827 Views)
You probably need to install the labview rte (It is not in the drivers i posted.), it would be in the labview install download.
Message 9 of 29
(8,821 Views)
Ok I am going to follow your process and see if I can at least get LabVIEW installed and running on Ubuntu. If that works then I will try with again on a fresh Ubuntu install with LabVIEW RTE.
Message 10 of 29
(8,811 Views)
