Linux Users
Announcing NI-DAQmx Base 3.7
NI-DAQmx Base 3.7 adds support for LabVIEW 2013. It drops support for LabVIEW 2009 and the LabVIEW Touch Panel Module. Support for openSUSE 12.2 was also added this release.
Here are some of the bugs that were fixed this release:
125793 - Boards that use DMA for analog input can now sample at full clock rates.
188602 - The Analog Input Samples Available property now correctly works for USB-600x and USB-92xx devices.
364104 - NI-DAQmx Base period measurement now uses the user specified timeout.
410911 - DAQmx Base utilities no longer require SSE2 CPU registers.
Message 1 of 1
(4,046 Views)
