Linux Users
Can Labview and NI-visa be installed on Mandriva 2010
Perhaps we have to consider our options:
  1. The long term solution is to again      allow the NI GPIB USB driver to access the USB subsystem symbols in      the kernel. If I understand the above info correctly, this can only      be done via an open source driver or a user mode program. What NI      strings do we have to pull to get this done?
  2. Does somebody on this list has      some knowledge about already existing open source kernel drivers      which can be used with the NI GPIB USB device.
  3. The short term solution, modifying      the Linux kernel and the nikal source. Is this already tested or are      we exploring here some uncharted territory. Can somebody on this      list give me some clues, recipe to get started?
Message 11 of 13
(668 Views)
1. if you can contact your NI sales representative for your area, it would help. How much it'll help depends on the size of the sales opportunity
2. I found this through google: http://linux-gpib.sourceforge.net/  .. it looks like it supports our gpib usb device. I've never tried using this before though.
3. I don't think I can legally tell you the steps to circumvent the license limitation, but you can certainly start from nikal source code and experiment yourself.
Sorry, not much I can help with.
Message 12 of 13
(668 Views)
@jchrisj
For all of their purity of spirit, the USB subsystem maintainers make it more difficult for me to use Linux and, in fact, constrain some of the freedom that the O/S is about.
No, they actually *increase* the freedom of the users (along w/ stability and security) by prohibiting unmaintainable and unauditable proprietary crap code.
(Why shouldn't I be able to taint my own kernel, particularly for internal use? It is one thing to give me options to closed source software and entirely another to not allow me to use closed source code if I want to.)
You still can. But this code the must not be redistributed. That's the deal, and it always has been with the GPL. In exchange, you get a whole OS for free, including source code.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
Message 13 of 13
(660 Views)
