Linux Users
Can linux-gpib and the NI (VISA etc) drivers (without 488.2) coexist?
Can linux-gpib and the NI (visa etc) drivers (without 488.2) coexist peacefully on one computer?
We would like to continue using the excellent NI GPIB-USB-HS adaptors (unsupported by the NI driver stack) via linux-gpib and access other, non-gpib hardware with VISA / DaqMX Base / ...
(I know that LabView and VISA applications cannot access the devices controlled by linux-gpib. Does not matter since we're only using the library bindings... they should just not interfere with each other's function...)
(4,083 Views)
AFAIK, that should work.. If it doesn't work, the main thing to look at is whether a driver you don't expect claims a device.. and in Linux, there's a way to tell linux not to let a specific driver take control of a particular device.. or so I thought.
(3,311 Views)
Makes sense, thanks! (and making sure only one driver claims a device is possible, certainly for USB.)
(3,311 Views)
