10-02-2018 07:38 AM
Hi all,
Thanks to NIDAQmx.h library and the related samples, I’ve developed a simple C++ program which was working perfectly until I was forced to reinstall the same Operating System, particularly Centos 7 as the first time.
I installed all the drivers and packages just like before and checked “nilsdev —verbose” command which returns the device name correctly. Unfortunately, now my code just runs till “DAQmxErrChk (DAQmxStartTask(taskHandle));” and after that just will stick in an infinite loop without any trying to run callbackFunction. Finally, I should stop the whole C++ program to exit.
How can I solve the problem?
Best regards
int main(void)
int32 error=0;
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateDIChan(taskHandle,"Dev1/port0/line0:7","",DAQmx_Val_ChanPerLine));
DAQmxErrChk (DAQmxCfgChangeDetectionTiming(taskHandle,"Dev1/port0/line0:7","Dev1/port0/line0:7",DAQmx_Val_ContSamps,1));
DAQmxErrChk (DAQmxRegisterSignalEvent(taskHandle,DAQmx_Val_ChangeDetectionEvent,0,ChangeDetectionCallback,NULL));
DAQmxErrChk (DAQmxGetTaskNumChans(taskHandle,&numLines));
// DAQmx Start Code
puts("Continuously reading. Press Enter key to interrupt\n");
puts("Timestamp Data read Changed Lines");
getchar();
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
Cleanup();
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
int32 CVICALLBACK ChangeDetectionCallback(TaskHandle taskHandle, int32 signalID, void *callbackData)
int32 error=0;
uInt8 data[200]={0};
int32 numRead;
uInt32 i=0;
char buff[512], *buffPtr;
char *timeStr;
time_t currTime;
if( taskHandle ) {
time (&currTime);
timeStr = ctime(&currTime);
timeStr[strlen(timeStr)-1]='\0'; // Remove trailing newline.
// DAQmx Read Code
DAQmxErrChk (DAQmxReadDigitalLines(taskHandle,1,10.0,DAQmx_Val_GroupByScanNumber,data,8,&numRead,NULL,NULL));
if( numRead ) {
buffPtr = buff;
strcpy(buff, timeStr);
strcat(buff," ");
buffPtr = buff + strlen(buff);
for(;i<numLines;++i) {
sprintf(buffPtr,"%d",data[i]);
buffPtr++;
strcat(buff," ");
for(i=0;i<numLines;++i) {
sprintf(buffPtr,"%c",data[i]==cachedData[i]?'-':'X');
buffPtr++;
cachedData[i] = data[i];
puts(buff);
fflush(stdout);
return 0;
Error:
Cleanup();
return 0;
void Cleanup (void)
if( taskHandle!=0 )
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
taskHandle = 0;
