03-04-2014 02:41 PM
Hello All,
I tried to install driver for NI USB 6210 on Unbuntu 12.04(32bit) according to (http://maztories.blogspot.co.uk/2013/03/ni-usb-6008-card-can-be-installed-in.html). but I failed for many times.I have searched kinds of solution on the network, but it still doesn't work.
It is essential for me to implement ongoing experiments on the unbuntu embeded with robot.
I hope you can help me. Thanks!!!
John
The error is as follows,
root@liang-PC-BX11948:/usr/local/natinst/nikal/bin# lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
libnipalu.so failed to initialize
Perhaps you need to run updateNIDrivers
/usr/local/bin/lsdaq: line 7: 4561 Aborted (core dumped) /etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices
I used NI-KAL v.2.2, NI-VISA v.5.4.0 and nidaqmxbase-3.7.0 for the installation.
When I ran nipal, error was follows,
root@liang-PC-BX11948:/usr/local/natinst/nikal/bin# '/etc/init.d/nipal' start
FATAL: Error inserting nipalk (/lib/modules/3.5.0-46-generic/kernel/natinst/nipal/nipalk.ko): Invalid module format
error: nipalk failed to load
possible causes:
nipalk was not versioned for this kernel (3.5.0-46-generic)
modules are not enabled for this kernel (CONFIG_MODULES)
unresolved symbols
possible solution:
if you recently installed a new kernel or have rebooted to
a different kernel from one you were previously running then run
/usr/local/bin/updateNIDrivers
to version your NI drivers for kernel 3.5.0-46-generic
03-04-2014 03:37 PM
You could be running into multiple problems here
* invalid module format -- sounds like you need to run updateNIDrivers again, to make nipalk.ko compatible with your kernel maybe?
* once nipalk can load, you still might not be able to find your USB device. Newer Linux kernel exports USB APIs in the kernel as EXPORT_SYMBOL_GPL. Thus, we can't use those and we can't control USB devices from the kernel.
The second one is unfixable with our current architecture. There are some works to move USB access to user mode using libusb, which is the recommended way, but I don't know the details of that effort.
03-04-2014 04:16 PM
Thank you for your timely answer. but I have run updateNIDrivers again and again and successful every time, nipalk can not be loaded yet.
When I ran nipal, error still occurred.
possible causes:
unresolved symbols
possible solution:
I will reinstall all the packages to see if it works. Can you give me some more guidance?
Thank you so much.
Best,
John
03-04-2014 05:02 PM
after nipalk tries to load, what does 'dmesg' give you, related to nipalk stuff?
03-05-2014 07:25 AM
There is only one message related to NIDAQ after running 'dmesg'
[ 201.539883] nikal: module license 'Copyright (c) 2002-2013 National Instruments Corporation. All Rights Reserved. Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
[ 201.539888] Disabling lock debugging due to kernel taint
[ 317.785029] audit_printk_skb: 39 callbacks suppressed
[ 317.785034] type=1400 audit(1394024155.848:25): apparmor="DENIED" operation="capable" parent=1 profile="/usr/sbin/cupsd" pid=936 comm="cupsd" pid=936 comm="cupsd" capability=36 capname="block_suspend"
I reinstalled all the files this morning, found that information with no warning or error as follows, but DAQ Devices does not work.
root@liang-PC-BX11948:~# lsdaq
I ran nipal seprately, same error occurred as follows,
root@liang-PC-BX11948:~# '/etc/init.d/nipal' restart
cat: /etc/natinst/nipal/nipal.dir: No such file or directory
I am eagerly need your help.
Thank you
John
03-05-2014 09:15 AM
We need dmesg output after you try to load nipalk. The dmesg output you pasted isn't related to nipalk. Can you attach the full output?
I'm not sure how useful this is. I'm very sure the kernel from 2012 already has EXPORT_SYMBOL_GPL for the USB subsystem in the kernel. I'm afraid that USB device won't work.
03-05-2014 10:43 AM
The whole output of dmesg is as follows,
[ 0.348846] pnp 00:05: [io 0x002e-0x002f]
[ 0.348847] pnp 00:05: [io 0x004e-0x004f]
[ 0.348848] pnp 00:05: [io 0x0061]
[ 0.348850] pnp 00:05: [io 0x0063]
[ 0.348851] pnp 00:05: [io 0x0065]
[ 0.348852] pnp 00:05: [io 0x0067]
[ 0.348853] pnp 00:05: [io 0x0070]
[ 0.348854] pnp 00:05: [io 0x0080]
[ 0.348856] pnp 00:05: [io 0x0092]
[ 0.348857] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.348859] pnp 00:05: [io 0x0680-0x069f]
[ 0.348860] pnp 00:05: [io 0x0200-0x020f]
[ 0.348861] pnp 00:05: [io 0xffff]
[ 0.348862] pnp 00:05: [io 0xffff]
[ 0.348864] pnp 00:05: [io 0x0400-0x0453]
[ 0.348865] pnp 00:05: [io 0x0458-0x047f]
[ 0.348866] pnp 00:05: [io 0x0500-0x057f]
[ 0.348888] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.348889] system 00:05: [io 0x0200-0x020f] has been reserved
[ 0.348891] system 00:05: [io 0xffff] has been reserved
[ 0.348892] system 00:05: [io 0xffff] has been reserved
[ 0.348894] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.348895] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.348897] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.348899] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.348904] pnp 00:06: [io 0x0070-0x0077]
[ 0.348911] pnp 00:06: [irq 8]
[ 0.348924] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.348939] pnp 00:07: [io 0x0454-0x0457]
[ 0.348961] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.348963] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.349025] pnp 00:08: [io 0x0000-0xffffffffffffffff disabled]
[ 0.349027] pnp 00:08: [io 0x0a00-0x0a0f]
[ 0.349028] pnp 00:08: [io 0x0a30-0x0a3f]
[ 0.349029] pnp 00:08: [io 0x0a20-0x0a2f]
[ 0.349048] system 00:08: [io 0x0a00-0x0a0f] has been reserved
[ 0.349050] system 00:08: [io 0x0a30-0x0a3f] has been reserved
[ 0.349051] system 00:08: [io 0x0a20-0x0a2f] has been reserved
[ 0.349053] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.349226] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.349231] pnp 00:09: [irq 4]
[ 0.349232] pnp 00:09: [dma 0 disabled]
[ 0.349268] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.349468] pnp 00:0a: [io 0x0378-0x037f]
[ 0.349472] pnp 00:0a: [irq 5]
[ 0.349473] pnp 00:0a: [dma 0 disabled]
[ 0.349555] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.349568] pnp 00:0b: [io 0x0010-0x001f]
[ 0.349569] pnp 00:0b: [io 0x0022-0x003f]
[ 0.349571] pnp 00:0b: [io 0x0044-0x005f]
[ 0.349572] pnp 00:0b: [io 0x0062-0x0063]
[ 0.349573] pnp 00:0b: [io 0x0065-0x006f]
[ 0.349574] pnp 00:0b: [io 0x0072-0x007f]
[ 0.349575] pnp 00:0b: [io 0x0080]
[ 0.349577] pnp 00:0b: [io 0x0084-0x0086]
[ 0.349578] pnp 00:0b: [io 0x0088]
[ 0.349579] pnp 00:0b: [io 0x008c-0x008e]
[ 0.349581] pnp 00:0b: [io 0x0090-0x009f]
[ 0.349582] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.349583] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.349585] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.349606] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.349608] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.349613] pnp 00:0c: [io 0x00f0-0x00ff]
[ 0.349617] pnp 00:0c: [irq 13]
[ 0.349630] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.349770] pnp 00:0d: [mem 0xfed1c000-0xfed1ffff]
[ 0.349771] pnp 00:0d: [mem 0xfed10000-0xfed17fff]
[ 0.349773] pnp 00:0d: [mem 0xfed18000-0xfed18fff]
[ 0.349774] pnp 00:0d: [mem 0xfed19000-0xfed19fff]
[ 0.349775] pnp 00:0d: [mem 0xf8000000-0xfbffffff]
[ 0.349776] pnp 00:0d: [mem 0xfed20000-0xfed3ffff]
[ 0.349778] pnp 00:0d: [mem 0xfed90000-0xfed93fff]
[ 0.349779] pnp 00:0d: [mem 0xfed45000-0xfed8ffff]
[ 0.349780] pnp 00:0d: [mem 0xff000000-0xffffffff]
[ 0.349781] pnp 00:0d: [mem 0xfee00000-0xfeefffff]
[ 0.349783] pnp 00:0d: [mem 0xdfa00000-0xdfa00fff]
[ 0.349818] system 00:0d: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.349820] system 00:0d: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.349822] system 00:0d: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.349823] system 00:0d: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.349825] system 00:0d: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.349826] system 00:0d: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.349828] system 00:0d: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.349829] system 00:0d: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.349831] system 00:0d: [mem 0xff000000-0xffffffff] has been reserved
[ 0.349832] system 00:0d: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.349834] system 00:0d: [mem 0xdfa00000-0xdfa00fff] has been reserved
[ 0.349836] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.349921] pnp 00:0e: [mem 0x20000000-0x201fffff]
[ 0.349923] pnp 00:0e: [mem 0x40004000-0x40004fff]
[ 0.349957] system 00:0e: [mem 0x20000000-0x201fffff] has been reserved
[ 0.349959] system 00:0e: [mem 0x40004000-0x40004fff] has been reserved
[ 0.349961] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.349976] pnp: PnP ACPI: found 15 devices
[ 0.349977] ACPI: ACPI bus type pnp unregistered
[ 0.349979] PnPBIOS: Disabled by ACPI PNP
[ 0.385626] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.385637] pci 0000:00:1c.4: PCI bridge to [bus 02-02]
[ 0.385640] pci 0000:00:1c.4: bridge window [io 0xe000-0xefff]
[ 0.385647] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.385667] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.385669] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.385670] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.385672] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.385673] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.385675] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.385676] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.385677] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.385679] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.385680] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff]
[ 0.385682] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.385683] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.385703] NET: Registered protocol family 2
[ 0.385738] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.385806] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.385988] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.386073] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.386074] TCP: reno registered
[ 0.386076] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.386080] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.386114] NET: Registered protocol family 1
[ 0.386122] pci 0000:00:02.0: Boot video device
[ 0.386181] PCI: CLS 64 bytes, default 64
[ 0.386183] DMAR: Host address width 36
[ 0.386185] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.386189] IOMMU 0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
[ 0.386190] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.386193] IOMMU 1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
[ 0.386194] DMAR: RMRR base: 0x000000d9ccc000 end: 0x000000d9cd8fff
[ 0.386195] DMAR: RMRR base: 0x000000db800000 end: 0x000000df9fffff
[ 0.386516] audit: initializing netlink socket (disabled)
[ 0.386521] type=2000 audit(1394023838.268:1): initialized
[ 0.404078] highmem bounce pool size: 64 pages
[ 0.404084] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.405548] VFS: Disk quotas dquot_6.5.2
[ 0.405577] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.405856] fuse init (API version 7.19)
[ 0.405902] msgmni has been set to 1556
[ 0.406110] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.406126] io scheduler noop registered
[ 0.406127] io scheduler deadline registered (default)
[ 0.406131] io scheduler cfq registered
[ 0.406270] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.406279] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.406320] intel_idle: MWAIT substates: 0x1120
[ 0.406321] intel_idle: v0.4 model 0x3A
[ 0.406322] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.406377] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.406380] ACPI: Power Button [PWRB]
[ 0.406403] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.406405] ACPI: Power Button [PWRF]
[ 0.406452] ACPI: Fan [FAN0] (off)
[ 0.406470] ACPI: Fan [FAN1] (off)
[ 0.406487] ACPI: Fan [FAN2] (off)
[ 0.406502] ACPI: Fan [FAN3] (off)
[ 0.406518] ACPI: Fan [FAN4] (off)
[ 0.406555] ACPI: Requesting acpi_cpufreq
[ 0.417460] Freeing initrd memory: 15180k freed
[ 0.421884] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.421886] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.421993] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.421994] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.422018] GHES: HEST is not enabled!
[ 0.422034] isapnp: Scanning for PnP cards...
[ 0.422066] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.442462] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.463470] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.463660] Linux agpgart interface v0.103
[ 0.464406] brd: module loaded
[ 0.464788] loop: module loaded
[ 0.464987] Fixed MDIO Bus: probed
[ 0.465010] tun: Universal TUN/TAP device driver, 1.6
[ 0.465011] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.465032] PPP generic driver version 2.4.2
[ 0.465056] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.465079] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.465082] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.465086] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.465104] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.468989] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 0.469001] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7c08000
[ 0.479696] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.479709] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.479710] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.479712] usb usb1: Product: EHCI Host Controller
[ 0.479713] usb usb1: Manufacturer: Linux 3.5.0-46-generic ehci_hcd
[ 0.479714] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.479785] hub 1-0:1.0: USB hub found
[ 0.479787] hub 1-0:1.0: 2 ports detected
[ 0.479829] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.479831] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.479834] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.479851] ehci_hcd 0000:00:1d.0: debug port 2
[ 0.483727] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 0.483738] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7c07000
[ 0.495695] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.495703] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.495705] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.495706] usb usb2: Product: EHCI Host Controller
[ 0.495707] usb usb2: Manufacturer: Linux 3.5.0-46-generic ehci_hcd
[ 0.495708] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.495766] hub 2-0:1.0: USB hub found
[ 0.495768] hub 2-0:1.0: 2 ports detected
[ 0.495799] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.495808] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.495835] usbcore: registered new interface driver libusual
[ 0.495865] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.496257] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.496260] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.496320] mousedev: PS/2 mouse device common for all mice
[ 0.496399] rtc_cmos 00:06: RTC can wake from S4
[ 0.496500] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 0.496524] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.496551] device-mapper: uevent: version 1.0.3
[ 0.496584] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 0.496596] EISA: Probing bus 0 at eisa.0
[ 0.496598] EISA: Cannot allocate resource for mainboard
[ 0.496599] Cannot allocate resource for EISA slot 1
[ 0.496600] Cannot allocate resource for EISA slot 2
[ 0.496600] Cannot allocate resource for EISA slot 3
[ 0.496601] Cannot allocate resource for EISA slot 4
[ 0.496602] Cannot allocate resource for EISA slot 5
[ 0.496603] Cannot allocate resource for EISA slot 6
[ 0.496604] Cannot allocate resource for EISA slot 7
[ 0.496605] Cannot allocate resource for EISA slot 8
[ 0.496606] EISA: Detected 0 cards.
[ 0.496647] cpuidle: using governor ladder
[ 0.496700] cpuidle: using governor menu
[ 0.496701] EFI Variables Facility v0.08 2004-May-17
[ 0.496880] ashmem: initialized
[ 0.496968] TCP: cubic registered
[ 0.497023] NET: Registered protocol family 10
[ 0.497131] NET: Registered protocol family 17
[ 0.497137] Key type dns_resolver registered
[ 0.497182] Using IPI No-Shortcut mode
[ 0.497305] PM: Hibernation image not present or could not be loaded.
[ 0.497319] registered taskstats version 1
[ 0.499372] Key type trusted registered
[ 0.500877] Key type encrypted registered
[ 0.502347] Magic number: 6:415:834
[ 0.502414] rtc_cmos 00:06: setting system clock to 2014-03-05 12:50:38 UTC (1394023838)
[ 0.502856] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.502857] EDD information not available.
[ 0.774475] isapnp: No Plug & Play device found
[ 0.774634] Freeing unused kernel memory: 764k freed
[ 0.774845] Write protecting the kernel text: 6068k
[ 0.774890] Write protecting the kernel read-only data: 2480k
[ 0.774890] NX-protecting the kernel data: 4172k
[ 0.786196] udevd[99]: starting version 175
[ 0.795637] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 0.799554] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.801829] ahci 0000:00:1f.2: version 3.0
[ 0.801874] ahci 0000:00:1f.2: irq 40 for MSI/MSI-X
[ 0.801919] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[ 0.801921] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.801925] ahci 0000:00:1f.2: setting latency timer to 64
[ 0.804395] r8169 0000:02:00.0: irq 41 for MSI/MSI-X
[ 0.804548] r8169 0000:02:00.0: eth0: RTL8168evl/8111evl at 0xf841c000, 94:de:80:e2:e9:11, XID 0c900880 IRQ 41
[ 0.804550] r8169 0000:02:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.808430] scsi0 : ahci
[ 0.810182] scsi1 : ahci
[ 0.810272] scsi2 : ahci
[ 0.811037] scsi3 : ahci
[ 0.811190] ata1: SATA max UDMA/133 abar m2048@0xf7c06000 port 0xf7c06100 irq 40
[ 0.811192] ata2: SATA max UDMA/133 abar m2048@0xf7c06000 port 0xf7c06180 irq 40
[ 0.811193] ata3: DUMMY
[ 0.811194] ata4: DUMMY
[ 0.927970] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 0.927975] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.928264] hub 1-1:1.0: USB hub found
[ 0.928333] hub 1-1:1.0: 4 ports detected
[ 1.039619] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.127606] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.127657] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.128216] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.128220] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f7431708), AE_NOT_FOUND (20120320/psparse-536)
[ 1.128576] ata2.00: ATA-8: TOSHIBA DT01ACA050, MS1OA750, max UDMA/133
[ 1.128581] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.129283] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.129296] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f7431708), AE_NOT_FOUND (20120320/psparse-536)
[ 1.129606] ata2.00: configured for UDMA/133
[ 1.130873] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.130887] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT0._GTF] (Node f74316c0), AE_NOT_FOUND (20120320/psparse-536)
[ 1.130894] ata1.00: ATAPI: ATAPI iHAS124 E, 4L03, max UDMA/100
[ 1.131951] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.131964] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT0._GTF] (Node f74316c0), AE_NOT_FOUND (20120320/psparse-536)
[ 1.131972] ata1.00: configured for UDMA/100
[ 1.133476] scsi 0:0:0:0: CD-ROM ATAPI iHAS124 E 4L03 PQ: 0 ANSI: 5
[ 1.136345] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.136350] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.136520] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.136583] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.136889] scsi 1:0:0:0: Direct-Access ATA TOSHIBA DT01ACA0 MS1O PQ: 0 ANSI: 5
[ 1.137069] sd 1:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.137071] sd 1:0:0:0: [sda] 4096-byte physical blocks
[ 1.137103] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1.137319] sd 1:0:0:0: [sda] Write Protect is off
[ 1.137321] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.137392] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.171912] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.171917] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.172316] hub 2-1:1.0: USB hub found
[ 1.172405] hub 2-1:1.0: 6 ports detected
[ 1.191132] sda: sda1 sda2 < sda5 sda6 > sda3 sda4
[ 1.192184] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.243643] usb 1-1.2: new low-speed USB device number 3 using ehci_hcd
[ 1.339627] usb 1-1.2: New USB device found, idVendor=093a, idProduct=2510
[ 1.339632] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.339635] usb 1-1.2: Product: USB Optical Mouse
[ 1.339638] usb 1-1.2: Manufacturer: PixArt
[ 1.343547] usbcore: registered new interface driver usbhid
[ 1.343548] usbhid: USB HID core driver
[ 1.344866] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
[ 1.344953] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[ 1.383503] Refined TSC clocksource calibration: 3092.973 MHz.
[ 1.383509] Switching to clocksource tsc
[ 1.443579] usb 2-1.1: new high-speed USB device number 3 using ehci_hcd
[ 1.535850] usb 2-1.1: New USB device found, idVendor=3923, idProduct=7269
[ 1.535852] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.607541] usb 2-1.5: new low-speed USB device number 4 using ehci_hcd
[ 1.669288] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.710886] usb 2-1.5: New USB device found, idVendor=1c4f, idProduct=0002
[ 1.710888] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.710890] usb 2-1.5: Product: USB Keykoard
[ 1.710891] usb 2-1.5: Manufacturer: USB
[ 1.713532] input: USB USB Keykoard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/input/input3
[ 1.713729] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:00:1d.0-1.5/input0
[ 1.716209] input: USB USB Keykoard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/input/input4
[ 1.716321] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:00:1d.0-1.5/input1
[ 9.540349] Adding 29295612k swap on /dev/sda6. Priority:-1 extents:1 across:29295612k
[ 9.544502] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.621095] udevd[363]: starting version 175
[ 9.953236] lp: driver loaded but no devices found
[ 10.049209] parport_pc 00:0a: reported by Plug and Play ACPI
[ 10.049258] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 10.052065] ACPI Warning: 0x00000460-0x0000047f SystemIO conflicts with Region \PMIO 1 (20120320/utaddress-251)
[ 10.052070] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 10.052072] lpc_ich: Resource conflict(s) found affecting iTCO_wdt
[ 10.052074] ACPI Warning: 0x00000428-0x0000042f SystemIO conflicts with Region \PMIO 1 (20120320/utaddress-251)
[ 10.052077] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 10.052079] ACPI Warning: 0x00000500-0x0000057f SystemIO conflicts with Region \LED_ 1 (20120320/utaddress-251)
[ 10.052081] ACPI Warning: 0x00000500-0x0000057f SystemIO conflicts with Region \GPIO 2 (20120320/utaddress-251)
[ 10.052084] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 10.052084] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 10.145652] lp0: using parport0 (interrupt-driven).
[ 10.155210] ppdev: user-space parallel port driver
[ 10.171957] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x17
[ 10.206584] mei 0000:00:16.0: setting latency timer to 64
[ 10.206631] mei 0000:00:16.0: irq 42 for MSI/MSI-X
[ 10.211731] mei 0000:00:16.0: wd: failed to find the client
[ 10.217644] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x17
[ 10.218597] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x17
[ 10.219410] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x17
[ 10.220218] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 10.242928] type=1400 audit(1394023848.240:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=656 comm="apparmor_parser"
[ 10.243211] type=1400 audit(1394023848.240:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=656 comm="apparmor_parser"
[ 10.243366] type=1400 audit(1394023848.240:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=656 comm="apparmor_parser"
[ 10.291417] [drm] Initialized drm 1.1.0 20060810
[ 10.382445] i915 0000:00:02.0: setting latency timer to 64
[ 10.382669] pci 0000:00:00.0: Intel Ivybridge Chipset
[ 10.382701] pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 10.383547] pci 0000:00:00.0: detected 65536K stolen memory
[ 10.383731] i915 0000:00:02.0: irq 43 for MSI/MSI-X
[ 10.383736] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 10.383737] [drm] Driver supports precise vblank timestamp query.
[ 10.384118] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.520514] [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
[ 10.785096] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 10.912309] fbcon: inteldrmfb (fb0) is primary device
[ 10.912368] Console: switching to colour frame buffer device 170x48
[ 10.912390] fb0: inteldrmfb frame buffer device
[ 10.912391] drm: registered panic notifier
[ 10.913695] acpi device:49: registered as cooling_device9
[ 10.913809] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 10.913840] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 10.913963] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.914050] snd_hda_intel 0000:00:1b.0: irq 44 for MSI/MSI-X
[ 11.019218] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 11.019352] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 11.019483] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 11.019620] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 11.019759] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 11.399529] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 12.088076] init: failsafe main process (862) killed by TERM signal
[ 12.358066] type=1400 audit(1394023850.356:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=928 comm="apparmor_parser"
[ 12.358422] type=1400 audit(1394023850.356:6): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=928 comm="apparmor_parser"
[ 12.375457] type=1400 audit(1394023850.372:7): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=974 comm="apparmor_parser"
[ 12.375726] type=1400 audit(1394023850.372:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=973 comm="apparmor_parser"
[ 12.375759] type=1400 audit(1394023850.372:9): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=974 comm="apparmor_parser"
[ 12.375924] type=1400 audit(1394023850.372:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=974 comm="apparmor_parser"
[ 12.375961] type=1400 audit(1394023850.372:11): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper//chromium_browser" pid=973 comm="apparmor_parser"
[ 12.499552] Bluetooth: Core ver 2.16
[ 12.499566] NET: Registered protocol family 31
[ 12.499567] Bluetooth: HCI device and connection manager initialized
[ 12.499568] Bluetooth: HCI socket layer initialized
[ 12.499569] Bluetooth: L2CAP socket layer initialized
[ 12.499571] Bluetooth: SCO socket layer initialized
[ 12.514040] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.514042] Bluetooth: BNEP filters: protocol multicast
[ 12.550733] r8169 0000:02:00.0: eth1: link down
[ 12.550742] r8169 0000:02:00.0: eth1: link down
[ 12.550874] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 12.551118] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 12.566276] Bluetooth: RFCOMM TTY layer initialized
[ 12.566280] Bluetooth: RFCOMM socket layer initialized
[ 12.566281] Bluetooth: RFCOMM ver 1.11
[ 14.504424] r8169 0000:02:00.0: eth1: link up
[ 14.504499] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 134.087037] usb 2-1.1: USB disconnect, device number 3
[ 164.471669] usb 1-1.1: new high-speed USB device number 4 using ehci_hcd
[ 164.563899] usb 1-1.1: New USB device found, idVendor=3923, idProduct=7269
[ 164.563904] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1163.369534] type=1400 audit(1394025001.620:26): apparmor="DENIED" operation="capable" parent=1 profile="/usr/sbin/cupsd" pid=936 comm="cupsd" pid=936 comm="cupsd" capability=36 capname="block_suspend"
[ 2843.324429] type=1400 audit(1394026681.949:27): apparmor="DENIED" operation="capable" parent=1 profile="/usr/sbin/cupsd" pid=936 comm="cupsd" pid=936 comm="cupsd" capability=36 capname="block_suspend"
[10401.259335] type=1400 audit(1394034241.549:28): apparmor="DENIED" operation="capable" parent=1 profile="/usr/sbin/cupsd" pid=936 comm="cupsd" pid=936 comm="cupsd" capability=36 capname="block_suspend"
03-05-2014 01:14 PM
ugh, sorry, doesn't look like there's nipalk-related message from trying to load nipalk there. I honestly don't know what the problem is..
"Invalid module format" doesn't really give me much to go on.
03-05-2014 04:12 PM
Thank you very much all the same. It confused me for days. I will try again, because I have no choice to choose other OS. if there is new problem, I will ask you soon.
John
03-05-2014 04:23 PM
I appreciate your attitude and not complain on this.. ![]()
Do you have to use ubuntu ? we don't support Ubuntu unfortunately..
But even in newer Linux version, you'll have problems with the USB stuff from the EXPORT_SYMBOL_GPL I referred to.
If you want to get that device to work, your option is limited to old Linux distributions that still have the USB subsystem in the kernel open to non-gpl use. That's pretty old.
Even in the link you referred to use Ubuntu 10.10:
"Ubuntu Server ((is tested in Ubuntu Server 10.10 but is easy to export to another version) Other users are having problem to export this solution to more recent Ubuntu version, so maybe is not so easy. If you try to do it, you have been warned, but invite you to write here your results. Maybe, you can help us. "
read this: http://www.linux-magazine.com/Online/News/Linux-2.6.25-without-Closed-Source-USB-Drivers
Sorry man, that's out of our hands. Refactoring our driver code to fix this is _HUGE_ amount of work..
There's more hope for new devices to address this, than older devices.. but that work also has to compete for prioritization with other tasks.
