Linux Users
Could DAQmx support 4G+ memory in RH6.0?
Hi there,
OS: RedHat 6.0 with 4G memory,
I use nilsdev commnad and could not find any DAQmx devices such as 6259 and 6733.  Could DAQmx linux driver support 4G+ memory?
Terry
(5,038 Views)
4G+ is not supported.
Execute the dmesg command. If you see a warning/error about 4G+ memory, you need to add mem parameter to grub menu list.
(4,857 Views)
Why not ? What's the exact problem ?
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(4,478 Views)
