Linux Users
DAQmxBaseError -200428
oe- I am seeing this error when I try to perform dio twice in a function that is contained in a subroutine (in a separate file):
DAQmxBase Error -200428: Value passed to the Task/Channels In control is invalid.
an outline of the code is below.  We have two files- the main file and the subroutine file.  In the main file, I have:
#define DAQmxErrChk(functionCall) { if(DAQmxFailed(error=(functionCall)) ) {goto Error; }}
int writeDigPort(TaskHandle taskhandle,int,int);  //This is the dio subroutine
int main(void) {
        TaskHandle taskHandleDO = 0;
        int direction ;
// Set Channel Numbers, filenames
        char chan[] = "Dev1/port1";
// Task parameters
        int32     error=0;
        char errBuff[2048];
// Begin Program
    DAQmxErrChk (DAQmxBaseCreateTask ("",&taskHandleDO));
    DAQmxErrChk (DAQmxBaseCreateDOChan(taskHandleDO,chan,"",DAQmx_Val_ChanForAllLines));
    DAQmxErrChk (DAQmxBaseStartTask (taskHandleDO));
        direction = 1;
    DAQmxErrChk (writeDigPort (taskHandleDO,1,direction));  //This is the dio subroutine call
        usleep(1000000);
    direction = 0;
In the subroutine file, I have:
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
int writeDigPort(TaskHandle  taskHandleDO, int lineNum,int direction)
    int32       error = 0;
   char        errBuff[2048];
  uInt32      w_data[1];
   int32       written;
   if(direction == 0) {w_data[0]=0;} //set all channels to zero
   else {w_data[0]=lineNum;} //turn on selected channel
   DAQmxErrChk (DAQmxBaseWriteDigitalU32(taskHandleDO,1,1,10.0,DAQmx_Val_GroupByChannel,w_data ,&written,NULL));
The subroutine is called twice by the main program.  The first time it works, the second time I get the error shown above.   I looked up the error number, but all I found was this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9MvSAK&l=en-US
which assumes labview is being used.
Any thoughts?
thanks,
eric
Message 1 of 1
(3,347 Views)
