Linux Users
Debugging LabVIEW Application
I am trying to debug a LabVIEW application. I checked the "Enable debugging" checkbox in build properties (but not the "Wait for debugger to launch" box), made a new build and started it. After the application started, I went back to LabVIEW, selected "Debug application or shared library" and selected localhost. Now, my problem is this: "No debuggable applications or runtime libraries found".
Does remote debugging work on Linux? If yes, should I open any particular ports in the firewall?
My system: LabVIEW 2009 SP1 on openSUSE 11.1.
Thanks!
(7,305 Views)
The "good" news (if you can call it that) is that I was also not able to get it to work, so it's not just you. The bad news is...I also couldn't get it to work. I tested 2009 and 2010. I filed a bug report (CAR# 294646) for the issue, but in the meantime I'm afraid you might just have to debug in the development environment.
(5,029 Views)
Another developer tried it, and he found that it worked for him. It turns out it didn't work for me because I had a custom .conf (/.ini) file, and the debugging feature needs to add some settings. I was basically overriding those. Do you have your own custom settings file for your application as well? If so then try adding these two settings:
DebugServerEnabled=True
DebugServerWaitOnLaunch=False
(5,029 Views)
Problem solved! I do have a custom .conf file. Thanks a lot Adam!
(5,029 Views)
