Linux Users
How to get VISA and Py-VISA running with Ubuntu 12.04?
Since i am running Ubuntu 12.04 with a 3.2.0-38 kernel the installation of NI-VISA, which i need to communicate with a vector network analyzer, is not straightforward (when I run the INSTALL of the mounted .iso image, i get 'ERROR: 3.2 kernels are not supported!'etc.). I have come across various solutions online, although none tried for 12.04. I am definitely not an expert in Linux, but i can have been getting along OK so far: what is your advice to overcome this problem the most easy way... has anyone had any experiences with Ubuntu 12.04?
(6,252 Views)
I think that error is fixed with the latest NI-KAL: https://www.ni.com/en/support/downloads/drivers/download.ni-kal.html
Try installing this latest ni-kal first, then continue with installing the rest of them.
Ubuntu sadly remains unsupported distribution though
(3,905 Views)
an other way is to take an ethernet to serial converter. So you have just to open a tcp connection in LabVIEW and everything you send he will write on the serial bus.
In our experimantel instruments we use the NPort converter from Moxa to communicat over Ethernet. Normaly you can use a driver so you have an addition seriell port.
But the Nport converter are able to run in the TCP Server-mode so it work like i discribe above.
cu
Oliver
(3,905 Views)
I try to install NI-VISA 5.3.0 on Ubuntu 12.04 and becomme this error
* The version of gcc in the path does not match the version of gcc used to compile the currently running
* kernel. This can cause unpredictable behavior in kernel drivers and should be fixed.
* gcc version: gcc-Version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5)
* kernel compiled with: 4.6.3
Can Anyone help me to fix it ?
(3,905 Views)
