Linux Users
How to install NI USB 621X driver on unbuntu 12.04 64bit?
Hello All,
Can you give me some guidance on How to install NI USB 621X driver on unbuntu 12.04 64bit?
Previously, I successfully installed the driver on ubuntu 12.04 32bit . but I have to change my pc to unbuntu 64bit for further research.
I tried to install the driver with previous method. but I failed.
When I input lsdaq, it shows:
lsdaq: command not found
I find the lsdaq file and run in the terminnal, following error occurs:
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
/etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices: error while loading shared libraries: libdaqmxbase_listdevices_so.so.3: cannot open shared object file: No such file or directory
I need your help badly
Thank you.
Kind regards,
John
(4,558 Views)
Hello, your error is in the description. NiDAQmx package, which supports you devices, supports linux 32-bit. You should install and try it under Ubuntu 32-bit.
(3,770 Views)
Hi, Thank you for your answer. It did work on ubuntu 32-bit, but is there any way to make it work on ubuntu 64bit?
John
(3,770 Views)
Hi, First time I installed DAQmx into Mageia 2 64-bit. I think, I got the same error as you. After it didn't workaround on it. I installed Mageia 2 32-bit, which worked with DAQmx without problem.
(3,770 Views)
