Linux Users
How to synchronize with MH DDK and MI products support on MH DDK?
I have an enduser using Schentific Linux6.2.
We have to use Linux environment, and trying MH DDK.
We have looked into many sources as you can see below.
However, we do not see the examples of Hardware timed synchronization for AI using M series or X series DAQ devices..
Is it not possible?? If thre is any good samples for reference, we all really appreciate it.
Also, once the devices turned out to be MI products, such as digitizers and DMMs, is it not possible to use the
MH DDK to control MI hardware? MH DDK does not seem to support MI products originally..
With the digitizers, it is a must to be able to use the synchronization between several AI channels  for the endusers..
Is there any way to do the Register Level Programming with MH DDK for synchronization of NI-digitizers/ NI-DMM??
Thank you so much.
Best Regards,
Hiroaki
Reference:
http://ae.natinst.com/public.nsf/web/searchinternal/c1313ca7de58d3b486256dab007410e9?OpenDocument
http://ae.natinst.com/public.nsf/web/searchinternal/6ae18df14a273ad786256b13005ff8b3?OpenDocument
http://digital.ni.com/public.nsf/websearch/1C3988D7D33B925C86256C59007FB4B4?OpenDocument
http://digital.ni.com/public.nsf/websearch/1C3988D7D33B925C86256C59007FB4B4?OpenDocument#RLP Examples
http://digital.ni.com/public.nsf/allkb/2D93070A3DDEFD7186256C59007289E6#hwsupport
http://digital.ni.com/public.nsf/allkb/F4FEA84797FF1F2186256F6B005D8761
Message 1 of 1
(11,614 Views)
