Linux Users
INSTALL.norpm
Hello, I'm trying to run LabVIEW Linux 2015 on an Ubuntu machine since Ubuntu is the official distro at work. The install CD has some binaries and an install script for non-rpm distro, but the script is terribly out of date and complains about not finding LabVIEW 8.1.1. Can someone provide an updated script for 2015?
As an alternative I can build on CentOS, but need to deploy the exe on Ubuntu. Assume I will need to install the runtime engine separately since the Linux application builder will not allow me to build an installer. Any experience with installing the runtime engine on non-rpm distros?
Richard
(4,149 Views)
Hey Richard,
Which version of Ubuntu are you using? Is it 32-bit or 64-bit? Do you need the 32-bit runtime engine or the 64-bit? I'd like to help you out if you could provide these info. Thank you.
Cheers,
Yanjiang
(3,734 Views)
