Linux Users
Install DAQmx801f0 on PXE OpenSuse 11.0 (diskless target)
Hi.
Currently working on a PXI4472.
I am trying to install DAQ8.1
My target board is diskless, so I boot OpenSuse 11.0 via PXE.
Most of the folders (e.g /bin /usr) are NFS Mounted with Read Only option.
So I install DAQ on the Server Machine.
This works fine.
When I exec nilsdev, it works (but I have no PXI board on the server machine)
When I exec nilsdev on the target board, I get an on libnipalu (libnipalu.so failed to initialize)
I tried to insmod the modules that were loaded in host machine but I still got the error on target board.
Any idea ?
Chris
ps : the UpdateNidrivers works only on host machine... On target it needs to write in Read Only folders...
(4,227 Views)
Hi.
Well, managed to remove the error on nilsdev...
I just added "/etc/rc.d/nipal start" and the "libnipalu.so failed to initialize" is gone.
I still have an issue because the nilsdev reports no board .
On the host with the same board I get NI PXI-4472:"Dev1".
Help welcome !
(3,532 Views)
Attaching reports of niSystemReport
One trace for the host where it works.
One trace for the target where it fails.
(3,532 Views)
Hi
Made it works ...
On my target I start my own init so I don't run any script of the rc folders of the host...
If it can help someone, to make nilsdev work, it needs :
- To have the lo network interface configured (need to add /sbin/ifconfig lo 127.0.0.1)
- To have Write acces to /usr/local/ (need to write some file into a max folder)
- To start the following services or process :
     /usr/local/natinst/max/sbin/nimxs /usr/local/natinst/max/libmxssvr.so
     /usr/local/sbin/nipalsm /etc/natinst/nipal/services/libnidevldu.so.1.4.1
     /usr/local/sbin/nipalsm /etc/natinst/nipal/services/libnipxirmu.so.1.6.0
Now the nilsdev show the plugged cards in my target system...
Chris
(3,532 Views)
