Linux Users
Labview Runtime Engine 2011 for Ubuntu does not work
Hi all, I have a problem, I have not been able to install the plugin Labview Runtime Engine 2011 for Ubuntu, this is originally for Suse, Redhat. I tried to install with alien for converting .rpm to .deb,
sudo alien ~/labview-2011-rte-11.0.0-1.i386.rpm
so far no problems, then i installed the .deb with the comand sudo dpkg -i labview-2011-rte-11.0.0-1.i386.deb
but i had no luck, after that i loaded a embedded page thorugh web publishing tool, but it said: Not installed the plugin. I do not what to do, if somebody can help me, i would appreciate it.
(7,777 Views)
In the post script in the RPM, the plugin is copied to a bunch of different locations if they can be found. I'm not sure if alien is alloing those scripts to be run or not. The error message if a location cannot be found is the following:
An error occurred trying to install the LabVIEW web browser plugin.
If you have Netscape 6, Mozilla, or Firefox installed in a
non-standard location, copy /usr/local/lib/LabVIEW-2011/LV2011NPlugin.so to its
'plugins' subfolder.
It tries to copy it into a bunch or old plugin folders if they exist as well as to the /usr/lib/browser-plugins folder that is the new default location for plugins. Try manually copying the file there and see what happens.
(5,445 Views)
Hi, thanks for your reply, I changed my mind and i installed the rpm in opensuse 12, but i have another trouble, when i open the vi through web publishing tool, i see the next messasge:
The National Instruments labVIEW plugin has crashed. Not report available. I have already copied the file LV2011NPlugin.so to the directory of firefox browser plugin.
Please, could you help me. Thank you.
Plugin LVRTE Linux crashed.pngI attach a capture.
(5,445 Views)
Make sure you are running firefox in 32-bit mode since the plugin is 32-bit only. And then make sure that you have all of the 32-bit compatibility libraries installed that you can find (x11, libstdc++, and such). Run ldd on the liblvrt.so and make sure everything can be found.
(5,445 Views)
Hi Randy, Im so embarrased for bothering you, I checked what you told me before, and i got this:
linux-lw30:/usr/local/lib # ldd /usr/local/lib/liblvrt.so ldd: warning: you do not have execution permission for `/usr/local/lib/liblvrt.so'
linux-gate.so.1 (0xb76f1000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0xb4f99000)
libXext.so.6 => /usr/lib/libXext.so.6 (0xb4f86000)
libX11.so.6 => /usr/lib/libX11.so.6 (0xb4e4c000)
libGL.so.1 => /usr/lib/libGL.so.1 (0xb4def000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb4d03000)
libm.so.6 => /lib/libm.so.6 (0xb4cbd000)
libdl.so.2 => /lib/libdl.so.2 (0xb4cb8000)
libpthread.so.0 => /lib/libpthread.so.0 (0xb4c9d000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb4c7f000)
libc.so.6 => /lib/libc.so.6 (0xb4ad8000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0xb4ab5000)
libglapi.so.0 => /usr/lib/libglapi.so.0 (0xb4a9f000)
libXdamage.so.1 => /usr/lib/libXdamage.so.1 (0xb4a9b000)
libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0xb4a95000)
libX11-xcb.so.1 => /usr/lib/libX11-xcb.so.1 (0xb4a91000)
libxcb-glx.so.0 => /usr/lib/libxcb-glx.so.0 (0xb4a78000)
libXxf86vm.so.1 => /usr/lib/libXxf86vm.so.1 (0xb4a72000)
libdrm.so.2 => /usr/lib/libdrm.so.2 (0xb4a65000)
/lib/ld-linux.so.2 (0xb76f2000)
libXau.so.6 => /usr/lib/libXau.so.6 (0xb4a61000)
librt.so.1 => /lib/librt.so.1 (0xb4a57000)
apparently the libraries what you told me there are.
I dont know if it is important but i had to create the "plugins folder" in the next locations because i could not find it, The locations where i created these were:
Root\usr\lib\firefox\plugins
home\.mozilla\plugins
in all of these i put the file LV2011NPlugin.so.
Excuse me again, but i am very worry about it cause  this is part of my work of degree, i really appreciate your help Randy.
(5,445 Views)
Do you have any other plugins installed in Firefox? The normal location now is /usr/lib/browser-plugins. Does this directory exist for you and is there anything in it (like maybe flash)?
(5,445 Views)
