Linux Users
Latest NI-KAL and dpkg- Possible Ubuntu/Debian support?
I tried the tutorial and got the same thing I got without it and similar to what I got with other versions of nikal.  This is nikal 1.10 on Debian 5.0.5 (2.6.26):
Uninstalling NI-KAL (nikal): done
/bin/rm -rf objects
Updating NI-KAL:
NI-KAL update failed.
/bin/cp nikal.c objects/nikal.c
/bin/cp nikal.h objects/nikal.h
make -C /lib/modules/2.6.26-2-686/build SUBDIRS=/usr/local/natinst/nikal/src/objects modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.26-2-686'
  CC   /usr/local/natinst/nikal/src/objects/nikal.o
/usr/local/natinst/nikal/src/objects/nikal.c:466: error: unknown field ‘nopage’ specified in initializer
/usr/local/natinst/nikal/src/objects/nikal.c:466: warning: initialization from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL120_getPageTablePMDEntry’:
/usr/local/natinst/nikal/src/objects/nikal.c:1779: warning: passing argument 1 of ‘pmd_offset’ from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL100_getKernelPageTableEntry’:
/usr/local/natinst/nikal/src/objects/nikal.c:1795: error: implicit declaration of function ‘pte_offset’
/usr/local/natinst/nikal/src/objects/nikal.c:1795: warning: assignment makes pointer from integer without a cast
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL100_mapUserPageTableEntry’:
/usr/local/natinst/nikal/src/objects/nikal.c:1808: warning: return makes pointer from integer without a cast
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL100_remapPageRange’:
/usr/local/natinst/nikal/src/objects/nikal.c:1883: error: implicit declaration of function ‘remap_page_range’
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL100_getPhysicalAddress’:
/usr/local/natinst/nikal/src/objects/nikal.c:1996: warning: assignment makes pointer from integer without a cast
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL100_decrementPageRefcount’:
/usr/local/natinst/nikal/src/objects/nikal.c:2032: error: ‘nLinux_physicalPage’ has no member named ‘count’
/usr/local/natinst/nikal/src/objects/nikal.c:2213:89: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/usr/local/natinst/nikal/src/objects/nikal.c: In function ‘nNIKAL100_createSystemThread’:
/usr/local/natinst/nikal/src/objects/nikal.c:126: error: ‘INIT_WORK’ undeclared (first use in this function)
/usr/local/natinst/nikal/src/objects/nikal.c:126: error: (Each undeclared identifier is reported only once
/usr/local/natinst/nikal/src/objects/nikal.c:126: error: for each function it appears in.)
make[2]: *** [/usr/local/natinst/nikal/src/objects/nikal.o] Error 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/objects] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.26-2-686'
make: *** [objects/nikal.ko] Error 2
ERROR: make of nikal kernel module failed, not installing kernel module.
   updateNIDrivers should be called again after fixing the problem.
   Logging failure...
   Include the file /tmp/niSystemReport.out.gz when contacting
   National Instruments for support.
So what am I missing?
Message 41 of 42
(756 Views)
configure wasn't finishing but it wasn't saying that, it just kept going until the make failed.  nikal is installed now.
Message 42 of 42
(756 Views)
