Linux Users
NI-DAQmx Base 3.4.5, is there linux users experiment returns ?
Hello Guys,
I see the nidaqmxbase 3.4.5 come in with some theorical improvement :
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/fr/pg/1/sn/catnav:du,n19:Linux,n8%3A347...
CHANGES FROM PREVIOUS VERSIONS
+3.4.0 --> 3.4.5
  *Added LabVIEW 2011 support
  *Removed LabVIEW 8.5(.1) support
  *Decreased the library load time when using the C API
Does it mean this solve the long time after "CreateTask" ?
In my logger based on custom linux binaries over a i486 1Ghz/128Mb embedded arch this take ~1min30, i hop this is solved !
http://digital.ni.com/public.nsf/allkb/F3CC0024B142BD1B862570EB00556711
Do you know something about ?
Can someone know if the :
- Does the "Daemonizing nidaqmxbase" problem is solved ?
- Does the "Bundling nidaqmxbase into lib" problem is solved ?
I have not enouth time to try at the moment, does a linux user user the NI-DAQmx Base 3.4.5, do you see some improvement ?
Thanks in advance for your experiment return
Rom1nux
Message 1 of 1
(3,586 Views)
