Linux Users
NI-KAL in SuSE Linux 11.4
NI-DAQmx Base brings user-mode drivers to Linux for several multifunction DAQ devices 🙂
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 21 of 47
(2,160 Views)
Well, I have decided to try the new version (2.9) of ni4882 in opensuse 11.4 (though in the readme only 11.2 and 11.3 appear as supported). It seemed to work pretty fine but I got the infamous libnipalu.so failed to initialize when executing gpibexplorer, although the installation apparently went well (only a couple of errors related to KDE and some mime types). I decided to uninstall (using the script provided in the package) and install again. The thing is that now, even when reporting a successful installation, nothing is actually installed:
NI-488.2 version 2.9.0f0
is about to be installed using rpm at /usr/local/natinst
Would you like to continue? [Yn]
Installing NI-488.2 version 2.9.0f0...
Pre Installation .
Post Installation .
Pre Installation ............
Post Installation ............
FOR PATENTS COVERING NATIONAL INSTRUMENTS PRODUCTS, REFER TO
THE PATENTS.txt FILE ON /home/joan/Downloads/ni4882-2.9.0f0 AND/OR
www.ni.com/patents
NI-488.2 Installation completed successfully.
pc6113:/home/joan/Downloads/ni4882-2.9.0f0 # cd /usr/local/natinst/
pc6113:/usr/local/natinst # ls
share
pc6113:/usr/local/natinst # cd share/
pc6113:/usr/local/natinst/share # ls
etc
pc6113:/usr/local/natinst/share # cd etc/
pc6113:/usr/local/natinst/share/etc # ls
share.dir
pc6113:/usr/local/natinst/share/etc # cd
pc6113:~ #
I have no gpibexplorer, no gpibtsw...
Any idea on what should I do to be able to actually install the thing again and proceed with the troublshooting?
Thanks.
Message 22 of 47
(2,161 Views)
Look in your kernel log file (syslog.log or kern.log), typically when nipal doesn't start, it's because nikal could not load. For suse, most of the time, it's because some symbol could not be found.
Try reading: https://decibel.ni.com/content/thread/8785
As far as installation goes, I'm not sure what's going on there.. sorry.
Message 23 of 47
(2,161 Views)
In regards to Gòl·lum's post...
I am installing Suse 11.4 and will try the same steps you took to reproduce the issue and investigate. I will update this forum when I get some more info about what is happening.
J. "Ox" Gibson
Systems Software / VISA Software Technician
That which doesn't kill me, better run REALLY fast.
Message 24 of 47
(2,160 Views)
Gòl·lum,
     Did you install the 32 bit or 64 bit version of Suse 11.4?
J. "Ox" Gibson
Message 25 of 47
(2,160 Views)
32 bit.
Message 26 of 47
(2,160 Views)
I got the installation to really succeed and now I am again with the
joan@pc6113:~> gpibexplorer
Perhaps you need to run updateNIDrivers
Aborted
I tried the operation suggested in the other post, though I had already done it (otherwise the installation would fail). Anyway, I repeated the zcat, cloneconfig and modules_prepare but the libnipalu.so error persists.
This is what I get in /var/log/messages (opensuse does not seem to use sys.log or kern.log):
Aug 23 12:11:35 pc6113 gpibexplorer: [nipalu]  Warning: source/lib/linux/linLoadKern.cpp:168 - libKernelDriverLoad: Failed to open nipalk, errno: 2
Aug 23 12:11:35 pc6113 gpibexplorer: [nipalu]  Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50204
Aug 23 12:11:35 pc6113 gpibexplorer: [nipalu]  Warning: source/package/posix/ulibEntry.cpp:179 - initialize: unable to load NI-PAL. status=-50204
Thanks for your reply.
Message 27 of 47
(2,161 Views)
search /var/log/messages for nikal, see what it says
Message 28 of 47
(2,161 Views)
This is what I get (after executing gpibexplorer)
pc6113:/home/joan # grep nikal /var/log/messages
Aug 23 10:51:11 pc6113 kernel: [  303.825096] nikal: module license 'Copyright (c) 2002-2011 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
Aug 23 10:54:08 pc6113 kernel: [   51.629389] nikal: module license 'Copyright (c) 2002-2011 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
Aug 23 11:00:01 pc6113 kernel: [   50.334596] nikal: module license 'Copyright (c) 2002-2011 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
Aug 23 11:08:25 pc6113 kernel: [   49.106368] nikal: module license 'Copyright (c) 2002-2011 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
Aug 24 16:03:39 pc6113 kernel: [   40.860541] nikal: module license 'Copyright (c) 2002-2011 National Instruments Corporation.  All Rights Reserved.  Any and all use of the copyrighted materials is subject to the then current terms and conditions of the applicable license agreement, which can be found at <http://www.ni.com/linux/>.' taints kernel.
pc6113:/home/joan #
It does not seem to be an error.
Message 29 of 47
(2,161 Views)
OK, sounds like nikal is loading OK.
grep nipal /var/log/messages and see what it says, could be related to  http://130.164.140.171/content/message/23838
If there's no obvious clue, please attach the output of niSystemReport here, to minimize back-and-forth.
Message 30 of 47
(2,161 Views)
