Linux Users
NI-VISA on 64-bit Linux
Try yum install libstdc++.i686
Message 11 of 16
(4,352 Views)
Do you need help?
Vinicius
Message 12 of 16
(4,346 Views)
Their kernel blob is 32bit - won't work on 64bit.
In essence: no chance.
NI obviously is too poor to afford a Linux kernel hacker for several month to write proper IIO drivers.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
Message 13 of 16
(4,281 Views)
Did you manage to fix it?
I am installing NI-VISA-17.0 on centos 6 and getting the similar error
Pre Installation ..............................................................................
error: Failed dependencies:
    libstdc++.so.6 is needed by ni-pal-17.0.0.49152-0+f0.i386
    libstdc++.so.6 is needed by ni-orb-nikalmod-17.0.0.49152-0+f0.x86_64
    avahi is needed by nisyscfgi-17.0.0-f0.x86_64
Error installing NI-VISA for Linux 17.0.0f1.
I checked glibc-devel it's already there.
Can you please help me how you fixed this issue?
Babar
Message 14 of 16
(3,984 Views)
Did you try yum install libstdc++.i686?  That should get the 32-bit libstdc++ needed by ni-pal-17.0.0.49152-0+f0.i386.  From the output it looks like you might also need to install 64-bit libstdc++ and avahi.
If you can, though, I'd use the 2018 drivers.  They are a clean break and do not coexist with pre-2018 NI drivers.  If you do not need any older drivers, though, the new way is much easier to install and manage.
Message 15 of 16
(3,783 Views)
I have the same problem on Centos 7 as well. It is not solved by
sudo yum -y install glibc.i686
The 64-bit version is located in /usr/lib64/libstdc++.so.6
Does anyone know how to resolve this issue?
Message 16 of 16
(3,689 Views)
