Linux Users
Need help with CentOS 5 and NIDaqMX
I am using the USB-6009 with the NISupport 15.0.0.0 with CentOS 7.  I have be suddenly tasked with making the same configuration work on a Centos 5.  The latest supported version I can find is NI-VISA-5.4.1 and DAQMx802f0 . I do not have LabView installed.
I cannot find a clear procedure on what I need and how to install the necessary support.  I do not that "nilsdev" produces no devices and the niSystemReport indicates the same.
Is this even going to be possible ?
I am kind of at a loss even where to begin to look for a solution to this problem.
Any pointer whatsoever would be appreciated.
(3,462 Views)
Why using such an ancient release at all ?
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,422 Views)
