Linux Users
OS didn't detect the PCI 6225 and PCI 6509 card anymore
Hi, I installed NIDaqmx Linux driver on CentOS 7.5. At the first it detected the cards installed on the motherboard correctly and I could check it using the command:
nidevls --verbose
Dev1
   BusType: PCI
   DevSerialNum: 0x129A763
   PCI.BusNum: 0x5
   PCI.DevNum: 0x2
   ProductNum: 0x716C
   ProductType: PCI-6225
Dev2
   BusType: PCI
   DevSerialNum: 0x12BDE0D
   PCI.BusNum: 0x5
   PCI.DevNum: 0x1
   ProductNum: 0x7085
   ProductType: PCI-6509
But today after a week, the driver couldn't detect them and it shows:
Dev1 [No Present]
   BusType: PCI
   PCI.BusNum: 0x5
   PCI.DevNum: 0x2
   ProductNum: 0x716C
Dev2 [No Present]
   BusType: PCI
   PCI.BusNum: 0x5
   PCI.DevNum: 0x1
   ProductNum: 0x7085
I checked and the NI Service is running. After every restart, a new device will be added to the output of the command
nidevls --verbose
I faced with the same problem a few weeks ago and after re-installing the OS and installing the NI driver again, it had been solved, but it happened again! How can I fix that?
(3,067 Views)
@soheil08
nidevls --verbose
Can you show an example of that?
(3,050 Views)
