Linux Users
OpenSUSE 10.3 and Labview - Database Connectivity
Hii Frinds,
I want to develop LabVIEW appplication in linux, which communicates with the Database.
Methods,database selection in all these aspects i need your ideas. Help me..
I m using OpenSUSE 10.3 and LabVIEW 8.6.
sankar.s
(5,888 Views)
The Database Connectivity Toolkit as you know is based on ActiveX and therefore can not be used under non-Windows systems. The way this has been done so far under Linux was to actually access the according C API for the database in question directly. I do for instance remember some efforts to access MySQL through its client side C API through the use of the Call Library Node.
I have myself worked on a more generic solution to make a library of VIs to access the ODBC API. This library works actually well on Windows for me but I have not found time to compile and test the underlaying DLL for Linux so far and do not foresee to get around that in the near future.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,584 Views)
