Linux Users
PXI module discovery on openSUSE 12.2
Hi Forum,
I am new to working with NI-VISA 5.4.0 on openSUSE 12.2. I am having difficulty seeing all the attached PXI modules when using visaconf or NIvisaic or my own code using the NI VISA API.
Here is my hardware configuration:
- openSUSE 12.2 is running on PXI-8196 module
- PXI-6722
- PXI-4060
- PXI-2585
- PXI-6509
Unfortunately, when I run NIvisaic with Machine: "localhost", I only see the following Devices:
- Unknown
-- ASRL8::INSTR
-- ASRL7::INSTR
-- ASRL6::INSTR
-- ASRL5::INSTR
-- ASRL4::INSTR
-- ASRL3::INSTR
-- ASRL2::INSTR
-- ASRL1::INSTR
- PXI Miscellaneous Resources
-- PXI0::MEMACC
This is the same I see using the API function calls in my own code.
Is there some tools or documentation to be used to configure all my PXI modules and make them visible?
Thanks!
- Sundeep
(3,843 Views)
I resolved it by uninstalling and reinstalling the NI DAQmx version 8.0.2. Now I have accessible to me several PXI devices that are installed on this system.
(3,288 Views)
