Linux Users
Problem with PyVisa (Ni-Visa/SL 5)
I am hoping that someone on these forums has seen this error, because I can't find anyone else reporting this problem on python forums or using a google search, which are my normal go-to problem solvers.
I am running Scientific Linux 5.2, and I was able to install the NI-VISA driver (5.1.2) with no problems. I was able to install PyVISA using their installer, but during the install it throws the following error
Extracting PyVISA-1.4-py2.4.egg to /usr/lib/python2.4/site-packages
  File "/usr/lib/python2.4/site-packages/PyVISA-1.4-py2.4.egg/pyvisa/visa.py", line 311
    CR = b"\r"
SyntaxError: invalid syntax
Despite this error, I can install from their egg in easy install. However, when I go to use PyVisa in python, if I try to call it as stated in the documentation
>>> import visa
Traceback (most recent call last):
  File "<stdin>", line 1, in ?
  File "visa.py", line 1, in ?
    from pyvisa.visa import *
    CR = b"\r"
Has anyone seen this error before? I have moderate experience with linux systems and python, and I have never had so much trouble installing things. Unfortunately, I don't know enough to know why this throws an error or what to do about it since I can't find any information on it with a google search.
Any help would be greatly appreciated.
Message 1 of 10
(19,013 Views)
    CR = b"\r"
It looks like your version of python might be confused by the string literal's representation. Does your system's python match what PyVISA requires?
Python documentation: String Literals
http://docs.python.org/reference/lexical_analysis.html#strings
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 2 of 10
(8,454 Views)
My system has Python 2.4, and PyVISA documentation states it requires a minimum of 2.3. The README file states  that their instructions were tested with Python 2.4, though not with my operating system, and with an older version of ctypes (they tested up to 0.9.5 and I have 1.0.2).
Message 3 of 10
(8,454 Views)
PEP 3112 says:
A string literal with a b in the prefix is always a syntax error in Python 2.5, so this syntax can be introduced in Python 2.6, along with the bytes type.
Brad Keryan
NI R&D
Message 4 of 10
(8,454 Views)
Can you see what's written on and around line 311 of the file throwing the error?
    CR = b"\r"
To me the variable name "CR" with a value of '\r' looks like it's just trying to define the carriage return as the byte representing '\r', which is usually the Mac version of the Unix '\n'. Usually I think this sort of thing is done when processing a file. However, if you look here:
http://www.python.org/dev/peps/pep-3137/#summary
it seems like that 'b' type is only defined in python 3.0a1 and up, i.e. not 2.4 or 2.7 or anything normal people use. In any event, with python 2.7.3 I can execute that statement without an error. Odd! Maybe you can redefine it, but it seems like a larger problem may be afoot.
Message 5 of 10
(8,454 Views)
    CR = b"\r"
Line 311 is
CR = b"\r"
I was initially tempted to try commenting it out, but a large portion of the file depends on it.
In a previous installation, I tried to update to Python 2.7, which resulting in more errors, but may or may not have been related to the fact that it was a 32-bit system.
I will try to upgrade python to 2.7 on this installation, since you were able to execute it without error, and report back.
Message 6 of 10
(8,454 Views)
I installed Python 2.7.3 and tested the line CR = b"\r" with no errors.
I installed PyVISA into Python 2.7.3, with no errors being thrown either during the initial installation or the installation of the egg.
However,  when I try to import it into Python
Python 2.7.3 (default, Jul  6 2012, 14:20:57)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-52)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import visa
  File "<stdin>", line 1, in <module>
  File "visa.py", line 1, in <module>
  File "/usr/local/lib/python2.7/site-packages/PyVISA-1.4-py2.7.egg/pyvisa/visa.py", line 231, in <module>
    resource_manager = ResourceManager()
  File "/usr/local/lib/python2.7/site-packages/PyVISA-1.4-py2.7.egg/pyvisa/vpp43.py", line 105, in __new__
    it.init(*args, **kwds)
  File "/usr/local/lib/python2.7/site-packages/PyVISA-1.4-py2.7.egg/pyvisa/visa.py", line 227, in init
    self.session = self.vi = vpp43.open_default_resource_manager()
  File "/usr/local/lib/python2.7/site-packages/PyVISA-1.4-py2.7.egg/pyvisa/vpp43.py", line 758, in open_default_resource_manager
    visa_library().viOpenDefaultRM(byref(session))
  File "/usr/local/lib/python2.7/site-packages/PyVISA-1.4-py2.7.egg/pyvisa/vpp43.py", line 175, in __call__
    self.load_library()
  File "/usr/local/lib/python2.7/site-packages/PyVISA-1.4-py2.7.egg/pyvisa/vpp43.py", line 146, in load_library
    self.__lib = self.__cdecl_lib = cdll.LoadLibrary(path)
  File "/usr/local/lib/python2.7/ctypes/__init__.py", line 443, in LoadLibrary
    return self._dlltype(name)
  File "/usr/local/lib/python2.7/ctypes/__init__.py", line 365, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: /usr/local/vxipnp/linux/bin/libvisa.so.7: wrong ELF class: ELFCLASS32
This is the same error I got using a different computer. At the time I though it was related to the fact that  the computer was a 32-bit. However, the computer I am now working on is a 64-bit, so that seems unlikely.
Has anyone seen anything like this before, or perhaps its a problem with the particular computers I'm using?
Message 7 of 10
(8,454 Views)
    self.load_library()
The "libvisa.so.7" file is an executable binary file (see http://en.wikipedia.org/wiki/Library_%28computing%29#Shared_libraries), and in this case it has been compiled for a 32-bit system. It doesn't look like NI-VISA for Linux supports 64-bit architectures, or if it does it only does so in 32-bit user mode: http://joule.ni.com/nidu/cds/view/p/id/2917/lang/en
Are you sure the other computer you were using was 32-bit? For 32-bit, the output of `uname -m` will be 'i686'; 64-bit will print 'x86_64'.
Message 8 of 10
(8,454 Views)
    self.load_library()
Are you sure the other computer you were using was 32-bit? For 32-bit, the output of `uname -m` will be 'i686'; 64-bit will print 'x86_64'.I
I double checked--the computer I was using is a 64-bit. I assumed it wasn't because it is rather old and in the past I had tried to install 64-bit operating systems without success, but that computer has many many problems.
Thank you for all your help. I will try to find an actual 32-bit computer try it out on.
Message 9 of 10
(8,454 Views)
Hello All,
I am using 64 bit windows machine.I have paythin version 2.5 and idle version 1.2
I have installed Pyvisa 1.4_32bit on my system.I want to use GBIP interface for my project.
If i run my Python script it is giving me error as below:
  File "C:\Users\rsap\Desktop\StreetFighter\I2C_Projects_ES10\dev_py - Copy\Reset Transistion.py", line 9, in <module>
    from visa import *
  File "C:\Python25\Lib\site-packages\visa.py", line 1, in <module>
  File "C:\Python25\lib\site-packages\pyvisa\visa.py", line 456
    self.term_chars = b""
Please help as soon as possible.Its very important for me.
Renuka
Message 10 of 10
(8,454 Views)
