Linux Users
RHEL 8.6 LabVIEW 2022, 2022 Q3 Drivers - Serial Error -1073807343
Upgraded my PXie-8135 to RHEL 8.6
NI-Serial and NI-VISA packages are installed
LabVIEW 2022
Drivers 2022 Q3
PXI-8433/4
The visaconf utility only recognizes the built-in serial port ASRL1 and binds to /dev/ttyS0
I have to statically add the ports from the PXI 8433 - I tried them as ASRL2 and binding to /dev/ttyS1 etc.
I added the user account to the dialout group.
Whenever I try and run the Configure Serial Port in LabVIEW on the PXI-8433 ports I get error -1073807343 resource not installed or available.
Am I missing a step here?
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(2,104 Views)
System admin found that he didn't install all of the drivers that come with the LV 2022 rpms - assumed that the ones labeled for prior years were not needed.
(2,076 Views)
If you are able to share more specifically about which packages were originally installed, and then what you discovered that you needed later, it would be of interest to me.
(2,065 Views)
