Linux Users
Setting voltage out on OpenSuse 11.1 for DAQ 6010
I also posted this question on the DAQ forums:
http://forums.ni.com/ni/board/message?board.id=250&thread.id=56035
I have been speaking with support, but folks on this forum may be better able to
answer my question.
I am using an NI 6010 multifunction DAQ and am unable to set the output voltage.
My platform is OpenSuse 11.1, with nikal 110 and daqmx801f.  Everything compiles etc,
and I am able to read voltages appropriately using the direct C interface.
I attempted to set the output voltage via:
DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-5.0,5.0,DAQmx_Val_Volts,"")
DAQmxWriteAnalogF64(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL)
But this does not work
I have a volt meter set up on pins 12 and 11 (12 being the ao0+ side and 11 being the ao0- side)
and am reading no output voltage.  This is basically the same code as the NI example  VoltUpdate.c, which
I am using for testing purposes while trying to get to the root of this issue.
Does anyone have any suggestions?
Thanks in advance.
Ps.  I was under the impression that OpenSuse 11.1 was supported, but apparently, I should revert to 11.0, are
other folks running 11.1 with no issues?
Message 1 of 1
(2,973 Views)
